Asma_LA
December 29, 2022, 9:52am
1
Hello everyone,
I need to model conduits along lines or polylines, but the Conduit.ByLine node is not working for me.
If I attach all the nodes, the file freezes with no result.
I see that there is a problem in the Conduit Type input, but I don’t know what to change exactly.
Do you have an idea how to solve this problem?
Hi @Asma_LA ,
ConduitType seems to be a reserved keyword. Update the MepOver package if you don’t have the latest version.
You can replace ConduitType by conduitType and save the custom node to obtain again the input.
Asma_LA
December 29, 2022, 10:03am
3
thank you for your replay,
I modified, the node was corrected. I have the latest version of the package.
But it doesn’t always work !
You can copy paste the Python script of the custom node in the canva.
Link the required inputs (line, level, diameter…) to the IN[0], IN[1] inputs.
Read the error above the Python script and show the error content in a new reply.
Asma_LA
December 29, 2022, 10:29am
5
Here’s what it looks like
You missed the input conduit type.
Asma_LA
December 29, 2022, 10:57am
7
when I attach it, my model pinwheels for infinity !
I tried several times but the same problem.
It is working fine for me with Revit 2022.
What is your curve input ? A line ?
Asma_LA
December 29, 2022, 11:29am
11
Yes, they are splines, but I tried with a straight line, and I have the same problem, and the model pinwheels for infinity.
T_Pover
December 29, 2022, 10:15pm
12
Is your graph set to run ‘automatic’? If so: set it to ‘manual’ instead.
Asma_LA
December 30, 2022, 8:23am
13
T_Pover Thank you very much for your help,
I have just tried it and it works, but the duct does not follow the spline, it was created in line.
But at least I get rid of the pinwheels problem.
Asma_LA
December 30, 2022, 11:33am
14
T_Pover I opted for this solution, drawing the lines one attached to the other and finally I attach the “Conduit.ByLine” node to the “Elbow.ByMEPCurves” node and it works well.
But as I have to import my splines from another software, it will take me more time to redraw them.
sovitek
December 30, 2022, 12:09pm
15
Hello @Asma_LA …think conduit can only be straight, but you could try remake the spline approximately…
Asma_LA
December 30, 2022, 12:27pm
16
sovitek Thank you for your solution, it looks like mine that I am creating.
In fact, I opted for a script to divide my curve into points, and then generate a polycurve. And then by selecting the polycurve it works very well.
I’ll test yours to choose the best one.
vick1z
June 5, 2024, 12:22pm
17
Hi Guys, Can I ask how to get Conduit.bylines node ? pls note its just the begining… appeciate your help !!! thanks
