I can not install any packages, i get this error: Empty path name is not legal (see attached)
Hi @SamBerk
Looks like your trying to install âDEPRICIATEDâ or old packages try installing packages which has got time stamp 2017.
You could ignore and hit âOKâ it will install the package. Itâs not error it is just asking your confirmation. FYI only.
I have already hit the âOKâ button and i get this error: Empty path name is not legal,
and after that when i search for it, i donât see it installed in the Dynamo library,
Thanks again
Have you tried restarting your PC?
Yes
@SamBerk Try this ->Unistall Dynamo completely and then reinstall again. See if that helps.
I have tried to uninstall and reinstall, and the same error message again: Empty path name is not legal
I donât know why, but now its works,
Hi Kulkul,
The problem is back i canât install packages, the same error message again: Empty path name is not legal
We are currently working on this issue. Sorry for any inconvenience.
Ok thanks,
You gonna let me know when itâs fixed?
Try now.
Try removing the downloads folder from the list of locations, restart your system, and give it another shot.
Didnât help,
I donât know about your setup, but I canât remember a situation where bulk users could create directories or otherwise access/edit content in folders at that level, but can in the C:\users\usernamegoeshere directory, so that may be the issue as Dynamo might not be able to create the desired subfolder for you.
Try doing a âinstall version to folderâ and see where dynamo is trying to save them to by default.
Set the directory to your desktop and see what happens from there.
