Hello guys, whats up?!
Im architecture student n im with a problem!
Always that i try to install some package at the Dynamo, an error occurs!
HEEEEEELP PLS"!
Was are the details of the crash?
ĂŤndice (baseado em zero) deve ser maior ou igual a zero e menor que o tamanho da lista de argumentos.
em System.Text.StringBuilder.AppendFormatHelper(IFormatProvider provider, String format, ParamsArray args)
em System.String.FormatHelper(IFormatProvider provider, String format, ParamsArray args)
em Dynamo.PackageManager.PackageManagerSearchViewModel.PackageOnExecuted(PackageManagerSearchElement element, PackageVersion version, String downloadPath)
em Dynamo.PackageManager.ViewModels.PackageManagerSearchElementViewModel.OnRequestDownload(PackageVersion version, Boolean downloadToCustomPath)
em MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
em System.Windows.Controls.Primitives.ButtonBase.OnClick()
em System.Windows.Controls.Button.OnClick()
em System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
em System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
em System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
em System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
em System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
em System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
em System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
em System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
em System.Windows.Input.InputManager.ProcessStagingArea()
em System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
em System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
em System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
em System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
em System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
em MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
em MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
em System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
em System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
em System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
em MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
em MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
em System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
em System.Windows.Application.RunDispatcher(Object ignore)
em System.Windows.Application.RunInternal(Window window)
em DynamoSandbox.Program.MakeStandaloneAndRun(String commandFilePath, DynamoViewModel& viewModel)
em DynamoSandbox.Program.Main(String[] args)
Are you installing this on your own laptop? My guess is that either you don’t have sufficient permissions or your AV/ASW is blocking write access due to the presence of DLLs in the package.
Yes, it is installed on my notebook, how do I fix it?
Try downloading them manually via your web browser.
Okay, n how i do to install it?
download it and place it in your package directory. then launch dynamo.
Very very thank you
