Can't install packages error: Empty path name is not legal
I have tried to install it to the desktop and this didn’t solve the problem
I’m still waiting for a solution,
Thanks guys
Hi @SamBerk
Install the packages from https://dynamopackages.com/
It should work for you.
@Kulkul
Finally! it works :slight_smile:
Thank you
@Kulkul @jacob.small @SamBerk
Hi all,
So i have tried to do the same procedure by manual installation from the website but it didn’t work, Packages are not showing in Dynamo. how you make it works ?
After downloading the package, you simply need to extract the contents to your package location.
Hi @jacob.small
this what i did but still not showing. any ideas
Add /packages to your path in the settings.
Hi Kulkul, how you doing brother, I got the same problem
Same issue for me (R2022).
Both manual installation as ‘normal’ installation doesn’t work.
The current version i was using (2022.210.2419) doesn’t show up in Dynamo (after manual installation). I also can’t re-install this version.
I can, however, install the latest version using ‘normal’ installation, but it also doesn’t show up in Dynamo after.
Edit
Solved! This made it clear to me
