Can´t connect pipes with fittings
Hi, i drew all the pipes with dynamo starting with a cad lines that´s ok, but the problem is that i don´t know how to connect this pipes with the fittings.
The pipes and the fittings are families for the same brand, so i think i have to use that particular fittings with this pipes.
And i want to create the pipes and fittigns automatically with dynamo.
Here are the special fittings that i need dynamo identify.
I think that´s possible. Can you help me?
Hello @pipelondo1996 and welcome
Yes it should be possible…here is a rough exemple…but its best if you show all your graph or upload your dyn then its easier to get help…
Revit_OJSA6xg8uG
Thank you for your answer, i want to try with your routine but i don´t understand some nodes like python script and the plane nodes. If you can explain me in short words i will be gratefull with you. Excuse me for my bad english haha.
(post deleted by author)
Hi @pipelondo1996 …the python node is from mepover, just modified a bit…it isnt super stable i will try go deeper when i have some time.how we can control which side the fitting will insert probably not so easy…but try something and play around with it …
Revit_ul3fQ2TjDH
MEP FITTING 45.rvt (6.1 MB)
1112 NEW_45 FITTING AFLØB MULTI.dyn (85.9 KB)
Hi @pipelondo1996 Here is an other dirty approach, but could probably work…
Revit_kV12R3Y2TA
Hi, i will try and i tell you. Thanks
