Goodday,
I’m currently trying to create fitting on the pipes that i created with detailcurves.
I can create the pipes but i can’t get the fittings to work.
What could i be doing wrong?
Goodday,
Hello @sven.deleau and welcome
Have you checked the routing preference if it’s correct ?
Can you share your rvt and dyn file?
Hi @c.poupin,
I’ve checked all preferences to “All”.
I can’t attach the file’s because i have created a new account recently. i will try to upload it from my other account.
Hi @sven.deleau …you can upload via webtransfer, filetransfer or whatever, just insert the link here
13. Inlezen pipes.dyn (116.2 KB)
The revit file is in the wetransfer link because it was to big, even after purging all the unnecessary stuf.
@sovitek
That’s the node i’ve used. I “exploded” the node so i could see the error in the python script.
OK…have tried to play around with some "passtrough nodes
That might actually be a thing. i will try that
Doesn’t seem to work. i even tried splitting up the scripts. Could i be using the wrong fittings and/or pipes?
@sovitek Brilliant!, somehow this works!
