I’m installing Camber from the package manager but it does not appear to be installing the full package. Below is a screenshot of what my install looks like.
Hi @jbaham,
It’s an issue I’m aware of and looking into a cause. Can you post which version of Civil 3D you are using? As a workaround you can install Camber v1.0.1 and see if that works.
Thanks for the response. I tried doing a search but couldn’t find where it had been previously posted.
Thanks, this is helpful. If you’re able to update to 2022.1 then it should work.
Please, I need offline update civil3d 2022.1 or link to explain to update
@mzjensen
You should be able to get it through the Autodesk Desktop App or at manage.autodesk.com.
