I am trying to install Camber package but I am getting the below error. Because of this some nodes are showing as ‘unresolved’. I have tried uninstalling and installing. My Dynamo version is 2.10 running on C3D 2022.
@zachri.jensen any suggestion what could cause this issue? I re-installed C3D but can’t get to the package install properly. Some of the nodes are missing from the package.
Hi @Gauzdx,
Which version of Civil 3D are you running? You can just run the ABOUT command and upload a screenshot.
Thank you for your reply.
Version:
OK, you’ll need to install the latest updates for Civil 3D 2022. Anything that is 2022.1 or newer should work.
