Camber Feedback Thread
Hi all,
Thanks to @shahid.shaikh_C3D and @hestingjj, I’ve become aware of an issue that will affect anyone using a version of Civil 3D less than 2022.1. You will likely see some type of error after installing Camber v2.0.0 that says “Failed to load library…” and portions of the Camber library may not show up as expected. This is because several of the nodes in Camber v2.0.0 rely on new additions to the Civil 3D API that were included in the 2022.1 update.
For now, your options are to (1) upgrade Civil 3D to 2022.1 if you can, or (2) stick with Camber v1.0.1 until I’m able to put together a fix. Sorry for the inconvenience! Next time you meet a developer that builds software to support multiple versions, give them a thumbs up…because it isn’t easy :slight_smile:
