Do you have any suggestion for families? Thank you
I need to convert 100s of family files to IFC which is tedious doing manually. I don’t see any automated solution on that link too. Thanks anyway @Marcel_Rijsmus
so you need a clean revit project file, place the family in there, export to IFC, delete the family and place the next and repeat this proces
i cannot test this (no Revit)
you have sent me a personal message, but that wont get you any help from the community, so please repost that message here.
thnx
It doesn’t seem possible to export IFC from families.
The export option is grayed out in the family interface.
The error with the Export IFC
node is “Exception: This Document is not a project document.”
In this case, the desired family file is loaded into the project file and the document .rvt project file is used here but problem remains unchanged!.
you are feeding the filename input with the string {3D}
i dont think you can create a file with a name like that
If you’re working in the Revit file, use the Export IFC
node. It’s simpler
Thank you for your help and
time both of you @Alban_de_Chasteigner , @Marcel_Rijsmus
i’ve tried this in dynamo 1.3 with the node as above but i’ve a couple of warnings.
Can you maybe help me with this?
Dave
Your issue has a distant relationship with the original subject, which is more than a year old.
Please, start a new topic
hi, Alban
your graph works fine but its I am facing one issue
Thank you
Thank you for your reply,
But still i am getting same problem. If u don’t mine can you check with my revit file. Below provided link.
Thankyou
This has nothing to do with the custom node but with the Revit IFC exporter engine.
This is the best I can do with the IFC exporter in Revit :
It cuts half of the floors.
You can post the issue to Autodesk here :
okay thank you for your help @Alban_de_Chasteigner…
I want to Batch export the Revit project file (.RVT) to IFC. I tried as per the screenshots. But I couldn’t find these 2 nodes.
- Get 3D views from document.
- Export IFC from document.
Please guide me on which package I need to download.
You will find these nodes in the Genius Loci package.
Cheers,
Thanks @Alban_de_Chasteigner ,
I downloaded the Genius Loci package and fetched it for these nodes. still, I am unable to find them.
Can you please upload the snapshot from your screen to find them?
Thanks so much for your help!
