HI Mikkel,
The explanation is there : Cannot close a linked file
You have two linked files in you list of Revit documents so this behaviour is expected.
It would be exactly the same in Revit : to open a linked file from the host document you must unload it.
You must do the same process as in post 12.
All of the files are central files. However, the files are linked into each other.
Normally opening 2 Revit files with the same links in one Revit instance can create problems as causing links to unload, could it be what is causing the issue? - Just a guess.
I managed to find a workaround. Since my files have absolute links, i just copied them to a new location, prior to exporting the views; thereby “detaching” the links causing the problems. This seems to work for now.
I can’t seem to make your custom node from post 14 work, which probably could have done the trick.
Do need a specific version of Dynamo to run this one?
I really appreciate your time and help!
(EDITED)
Glad you figured it out !
The Unload RevitLinkType from document node is in the latest update of Genius Loci package.
That exactly what I was trying to explain.
Hi Alban
Could you maybe share the “small change” you made to “Unload RevitLinkType from Document”? I have tried to change the Python part in the node but without any luck.
Thanks in advance.
The node has already been updated in the latest versions of the Genius Loci package.
Thank you embarrassed
try to make the graph exactly as in post 3
you have more inputs missing
Great - this seems to have sorted it! Thanks so much!
Thanks. Great help! But I am not able to find the following node. Can you please help ?
This node exists in many packages.
In Rhythm, Genius Loci and other.
i think this workflow is for project files, not families.
