What is this “ToRvtPoint”? I chose the points I wanted to tag in the selections, but what am I doing wrong?
I am adding the relevant .JPEG and code to the attachment.
Thanks.
MaterialTag.dyn (94.3 KB)
Thanks.
Can you open the node and copy the python code within into the topic? Looks like a system conversion problem. Also, what package/ package version is the node from? (As you look to be using Dynamo 2.0 at least)
Hi @Durmus_Cesur,
Add a List.Flatten node after the Geometry.Translate node.
The Create Annotation Tag doesn’t seem to work with material tags.
You can use instead the Create Annotation Tag (Multi-Category) node in Genius Loci package.
It’s a variation on the node of archilab so many thanks to Konrad Sobon.
If you are using Revit 2019 choose the Create Independent Tag node.
My Dynamo Vers. 2.02.02
#Copyright(c) 2015, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Import Element wrapper extension methods
# Import geometry conversion extension methods
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
locationPts = UnwrapElement(IN[0])
tagType = UnwrapElement(IN[1])
elements = UnwrapElement(IN[2])
if IN[4] != None:
link = UnwrapElement(IN[4])
link = None
RunIt = IN[5]
if isinstance(IN[3], list):
views = [UnwrapElement(i) for i in IN[3]]
views = UnwrapElement(IN[3])
def toRvtPoint(point):
return point.ToXyz()
def toRvtId(_id):
if isinstance(_id, int) or isinstance(_id, str):
id = ElementId(int(_id))
return id
elif isinstance(_id, ElementId):
return _id
def GetUVPoint(pt):
if type(pt) == Autodesk.DesignScript.Geometry.Point:
return Autodesk.Revit.DB.UV(pt.X, pt.Y)
elif type(pt) == Autodesk.DesignScript.Geometry.UV:
return Autodesk.Revit.DB.UV(pt.U, pt.V)
def CreateSpaceTag(space, uv, view):
return doc.Create.NewSpaceTag(space, uv, view)
tagTypeId = toRvtId(tagType.Id)
try:
errorReport = None
if RunIt:
if tagType.Category.Name == "Room Tags":
roomTags = []
if isinstance(views, list):
for i, j, k in zip(elements, views, locationPts):
roomId = LinkElementId(i.Id)
location = Autodesk.Revit.DB.UV(toRvtPoint(k).X, toRvtPoint(k).Y)
roomTag = doc.Create.NewRoomTag(roomId, location, j.Id)
roomTag.RoomTagType = tagType
roomTags.append(roomTag)
for i, j in zip(elements, locationPts):
if link != None:
roomId = LinkElementId(link.Id, i.Id)
location = Autodesk.Revit.DB.UV(toRvtPoint(j).X, toRvtPoint(j).Y)
roomTag = doc.Create.NewRoomTag(roomId, location, views.Id)
result = roomTags
elif tagType.Category.Name == "Space Tags":
roomTags = []
uv = GetUVPoint(k)
spaceTag = CreateSpaceTag(i, uv, j)
spaceTag.SpaceTagType = tagType
roomTags.append(spaceTag)
uv = GetUVPoint(j)
spaceTag = CreateSpaceTag(i, uv, views)
result = roomTags
tags = [\*]
for i,j,k in zip(elements, views, locationPts):
location = toRvtPoint(k)
tag = doc.Create.NewTag(j, i, False, TagMode.TM_ADDBY_CATEGORY, TagOrientation.Horizontal, location)
tag.ChangeTypeId(tagTypeId)
tags.append(tag)
location = toRvtPoint(j)
tag = doc.Create.NewTag(views, i, False, TagMode.TM_ADDBY_CATEGORY, TagOrientation.Horizontal, location)
tags.append(tag)
result = tags
result = "RunIt is set to False."
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
#Assign your output to the OUT variable
if errorReport == None:
OUT = result
OUT = errorReport
Yes, that code works really well. Thank you for the package and @Konrad_K_Sobon. Yet still “Element Locations Point” over the “Tag” is creating. In this case, the points I set are not important. I need to know what caused this situation.I examined the work on this situation and in the video, @Dimitar_Venkov has again spread its magic on us. I don’t want to explore America again.
Thanks.
*https://www.youtube.com/watch?v=RCn-eFZb2FU
Hi Durmus,
The node created material tags with the leaders and the locations were therefore incorrect.
It is now corrected in the last version of the package.
If your goal is to tag all materials, you can use the Wall CompoundStructureLayersLocation and Tag Set Location nodes.
Thank you very much for your help, really. The secret to this is “ListOfRepeatedItem”. Bonne Journée
