Is it possible to change the unit of measure to meters?
Hi Mark,
Is there a way for this python version to generate a single dimension line, instead of the chopped up version?
Thanks in advance
Tim
Apologies, this thread is so long I can’t even remember where it got to
I think it is about list management… You need to group all the references for each dimension into a sub-list, if you are getting chopped dimensions you are getting a pair of references for each dimension.
If you are unsure, I would start with creating what you want using nodes and then translate to Python, I believe Genius Loci has lots of useful nodes.
I hope that helps,
Mark
I was talking about the script where there’s basically only a python node (code is below).
The rest of the script works like a charm by the way, amazing work.
I’ve narrowed it down to this area (I think) but no amount of tinkering works (it doesn’t help that I don’t understand python much)
Here’s the code you’ve provided
#thanks for all the help everyone
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
clr.AddReference("ProtoGeometry")
from Autodesk.DesignScript import Geometry as geom
# Import Element wrapper extension methods
# Import ToProtoType, ToRevitType geometry conversion extension methods
from Autodesk.Revit.UI.Selection import ObjectType
def isParallel(v1, v2):
#it needs two vectors
return v1.CrossProduct(v2).IsAlmostEqualTo(XYZ(0, 0, 0))
def isAlmostEqualTo(v1, v2):
return v1.IsAlmostEqualTo(v2)
def isPerpendicular(v1, v2):
if v1.DotProduct(v2)== 0:
return True
return False
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
def CurveToVector(crv):
vec = geom.Vector.ByTwoPoints(crv.StartPoint,crv.EndPoint)
return vec
#set the wall orientation, depending on whether exterior or interior is selected
def wallNormal(wall, extOrint):
if extOrint:
wallNormal = wall.Orientation.ToVector()
wallNormal = wall.Orientation.Negate().ToVector()
return wallNormal
#this takes the wall location line, shifts it up the to the view cut plane
#and moves it out to the external edge of the wall
def locToCutCrv(wall, wallNormal, lineEndExtend):
wallLn = wall.Location.Curve
wallCrv = wallLn.ToProtoType()
#take the level height, subtract the height of the wall base
zOf = doc.ActiveView.GenLevel.Elevation-wallCrv.StartPoint.Z
#get the cut plane offset of the view
cPlaneH = doc.ActiveView.GetViewRange().GetOffset(PlanViewPlane.CutPlane) #the CutPlane enumeration is like a property of PBP?
cPlaneHiMM = UnitUtils.ConvertFromInternalUnits(cPlaneH, DisplayUnitType.DUT_MILLIMETERS)
wallCrv = geom.Geometry.Translate(wallCrv, geom.Vector.ByCoordinates(0,0, zOf+cPlaneHiMM))
wallwidthMM = UnitUtils.ConvertFromInternalUnits(wall.Width, DisplayUnitType.DUT_MILLIMETERS)
wallCrv = geom.Geometry.Translate(wallCrv, wallNormal, (wallwidthMM/2))
#get wall curve info
wallvec = CurveToVector(wallCrv)
wallorig = geom.Curve.PointAtParameter(wallCrv,0.5)
walldir1 = geom.Vector.ByTwoPoints(wallorig, wallCrv.StartPoint)
walldir2 = geom.Vector.ByTwoPoints(wallorig, wallCrv.EndPoint)
#move points
ptMvSt = geom.Geometry.Translate(wallCrv.StartPoint, walldir1, lineEndExtend)
ptMvEnd = geom.Geometry.Translate(wallCrv.EndPoint, walldir2, lineEndExtend)
#create new line based on extended points
#this is not a model line! that requires another method
lineAtExternalEdgeAtCutPlaneHeight = geom.Line.ByStartPointEndPoint(ptMvSt, ptMvEnd).ToRevitType()
return lineAtExternalEdgeAtCutPlaneHeight
offDist = IN[0]
extOrInt = IN[1]
#if the wall is exterior we need to extend the intersect line
#beyond the exterior face to pick up the intersecting walls
#if the wall is interior, we don't want to extend as far
if extOrInt:
intersectLineEndExtend = 500
intersectLineEndExtend = 0
#User Input
ref = uidoc.Selection.PickObject(ObjectType.Element, 'Select A Wall')
#define Targe Wall
targetWall = doc.GetElement(ref)
#let's go get the walls for finding references
intersectedWalls = []
#start by adding our target wall
intersectedWalls.append(targetWall)
#then get all the other walls in the view and test if they intersect the Target Wall
collectedWalls = FilteredElementCollector(doc, doc.ActiveView.Id).OfClass(Wall).ToElements()
for collectedWall in collectedWalls:
if targetWall.Location.Curve.Intersect(collectedWall.Location.Curve) == SetComparisonResult.Overlap:
intersectedWalls.append(collectedWall)
#Target Wall external line for intersect check
exLi = locToCutCrv(targetWall, wallNormal(targetWall, extOrInt), intersectLineEndExtend)
#Curve where the dimension will be located
offCrv = geom.Geometry.Translate(exLi.ToProtoType(), wallNormal(targetWall, extOrInt), (offDist))
#lets get the wall edges we want
#only get edges intersecting target side? no this is misleading... we want any reference hitting our external wall
#the problem is actually that the face itsetlf is registering the intersections we don't want e.g. the wrapping ends
frontFaceIW = []
vertEdges = []
opts = Options()
#without compute references, none of this works
opts.ComputeReferences = True
opts.IncludeNonVisibleObjects = True
opts.View = doc.ActiveView
for wallInt in intersectedWalls:
for obj in wallInt.get_Geometry(opts):
#walls also contain line geometry
if isinstance(obj, Solid):
for face in obj.Faces:
#if face is normal is equal to wall normal it is the external face
if isAlmostEqualTo(wallInt.Orientation, face.ComputeNormal(UV(0.5,0.5))):
frontFaceIW.append(face)
for edge in obj.Edges:
#get edges which intersect
edgeC = edge.AsCurve()
edgeCNorm = edgeC.Direction.Normalize()
#if front face edge and edge intersects line and edge is vertical up or vertical down add to list
if edgeC.Intersect(exLi) != SetComparisonResult.Disjoint and (edgeCNorm.IsAlmostEqualTo(XYZ(0,0,1)) or edgeCNorm.IsAlmostEqualTo(XYZ(0,0,-1))):
vertEdges.append(edge)
#so we use the X+Y values as a unique identifier of location (we're less interested in
#the actual unique reference, there may be 2 in the same place)
#we will use these as filtering and sorting values
#if we wanted to use this on sections we'd want to use z value?
vertEdgesLoc = []
for v in vertEdges:
vLoc = v.AsCurve().GetEndPoint(0).X + v.AsCurve().GetEndPoint(0).Y
#getting some revit rounding errors, 7dp should be enough!
vertEdgesLoc.append(round(vLoc,7))
#trying to remove stray intersect edges from adjoining walls
#to identify them, they are not on an intersecting wall front face
#their faces are not both on the target wall
#so we need all the target wall faces
for obj in targetWall.get_Geometry(opts):
faceTW = obj.Faces
#create a holding list containing everything in vertEdges
strayEdges = []
for v in vertEdges:
strayEdges.append(v)
#start removing things from holding list to leave only the stray ones
for faIW in frontFaceIW:
#if edge face 0&1 are both target wall faces we don't want to remove them
i = 0
length = len(strayEdges)
while (i < length):
if strayEdges[i].GetFace(0) in faceTW:
strayEdges.Remove(strayEdges[i])
length = length - 1
elif strayEdges[i].GetFace(1) in faceTW:
length = length - 1
#if our wall is external.... #if edge face is an intersecting wall's front face, we don't want it
elif strayEdges[i].GetFace(0) == faIW and extOrInt == True:
length = length - 1
elif strayEdges[i].GetFace(1) == faIW and extOrInt == True:
length = length - 1
# strayEdges.Remove(ed)
#or if the edge reference is to a non-wall
continue
i = i+1
#if the wall is exterior, we want to remove references to internal wall edge
if extOrInt == True:
i=0
length = len(vertEdgesLoc)
strayCLoc2 = []
while (i < length):
for stray in strayEdges:
stLoc = stray.AsCurve().GetEndPoint(0).X + stray.AsCurve().GetEndPoint(0).Y
#getting eroneous values, Revit accuracy not good enough? round is built in method
if round(vertEdgesLoc[i],7) == round(stLoc,7):
vertEdges.Remove(vertEdges[i])
vertEdgesLoc.Remove(vertEdgesLoc[i])
length = length - 1
continue
i = i+1
#sort the edges using the combined XY location value
vertEdgesSorted = [x for _,x in sorted(zip(vertEdgesLoc,vertEdges))]
vertEdgesLocSorted = sorted(vertEdgesLoc)
#only add uniquely located references
#this is awkward because we test 1 list, then add to the other list
#we need the Temp list, so we know what should be added to the Sub list
vertEdgeUniLocTemp = []
vertEdgeSub = ReferenceArray()
for eL, e in zip(vertEdgesLocSorted, vertEdgesSorted):
if eL not in vertEdgeUniLocTemp:
vertEdgeUniLocTemp.append(eL)
vertEdgeSub.Append(e.Reference)
#we want to pair up the references to create unique dims for the brick dim checker
#convoluted code, ref arrays seem their own beast!
outRefs = []
#define the overall list length
for i in range(vertEdgeSub.Size-1):
#create the array here so the list nesting is correct
vertEdgeAr = ReferenceArray()
#define the sub list length
while vertEdgeAr.Size < 2:
#only get add 2 indices for each sub list
vertEdgeAr.Append(vertEdgeSub[i])
vertEdgeAr.Append(vertEdgeSub[i+1])
outRefs.append(vertEdgeAr)
#OUT = len(strayEdges)
#start transaction
#create dimensions for each pair of referenes
for ref in outRefs:
dim = doc.Create.NewDimension(doc.ActiveView, offCrv.ToRevitType(), ref), outRefs,
#finish transaction
Hey, so first off, if you look here:
https://www.revitapidocs.com/2015/47b3977d-da93-e1a4-8bfa-f23a29e5c4c1.htm
You will see that for every dimension we need a View, Line and Reference Array.
My code happens to have a Reference Array called vertEdgeSub, and you don’t need to break it down and pair it up, so I think you can just use that…
(delete ‘for ref in outRefs:’ and delete any spaces before ‘dim’ so it sits at the beginning of the line)
dim = doc.Create.NewDimension(doc.ActiveView, offCrv.ToRevitType(),vertEdgeSub)
If that doesn’t work, if you could post a screen grab of your code and the warning message above the Python node we can see what is going wrong.
Hope that helps,
Mark
Oh wow that is a usefull site.
When I start coding for real that is gonna be a huge help, thanks!
It didn’t work at first, said there was an inconsistency of references, but this did work so thank you!
dim = doc.Create.NewDimension(doc.ActiveView, offCrv.ToRevitType(), vertEdgeSub), outRefs,
someone resolves it? i need help :C
Change the following in the code (lines 76 & 78)
to
cPlaneHiMM = UnitUtils.ConvertFromInternalUnits(cPlaneH, UnitTypeId.Millimeters)
locPositionMM = UnitUtils.ConvertFromInternalUnits(locPos, DisplayUnitType.DUT_MILLIMETERS)
to
locPositionMM = UnitUtils.ConvertFromInternalUnits(locPos, UnitTypeId.Millimeters)
Same error here
has anyone had any luck with finding out the problem is on line 76 and line 124
Somebody can help me if this error
:Chart name, 1 Click Dimension Wall (1)
Node, Type, Message, URL
Python Script,WARNING,“PythonEvaluator. Evaluate.Traceback operation failed (most recent call last): File “””“, line 124,
in File “””“, line 76, in locToCutCrvNameError: global name ‘DisplayUnitType’ is not defined”,undefined
AutoDim.dyn (56.7 KB)
can someone will help with it, tons of thanks
Você conseguiu resolver? Também estou procurando uma rotina que faça isso
