If you can turn Element Binding to you’re advantage, even better.
Just keep running the script until you have what you need
yes exactly
Hello im not sure where your node is from it isnt that one i mention, but if you are in 2022 something here could work…
Unfortunately I am using Revit 2021, I have installed the synthesize tool kil it have the same nodes , it just says Var before each input, may I ask what version did you install
I have installed this one
Thanks a lot for the help
arhhh you are in 2021 then spring "family instance by geometry work as i show in post #17
Thanks a lot , the wall.byface node doesn’t allow me to add voids or edit the walls or add doors am I Right ?
This works for now but is there anyway I can edit the walls profile using Dynamo ? Or use the attach top/base node in Dynamo ?
If not I guess I have to stick with this one
yes that method have some limits,but should be possible insert doors and windows, not sure about voids
