Hi There,
I found a very helpful script online that allows one to rename elements in a specific format by using a spline to determine the ordering sequence.
I was using this perfectly fine at home last night but when I run it at work this morning I get the attached error message and the script fails.
Does anybody understand the reason it’s failing? I don’t quite see how it could work perfectly yesterday and fail today. I’m even running it in the exact same project as I was using last night.
Error message and script attached below.
If anybody could help out with a solution or direct me to a similar post it would be greatly appreciated.
Thanks in advance.
Script:
Renumbering Wizard_V1.dyn (19.1 KB)
Error Message:
