Face.vertices error (clueless student)
Warning: Face.Vertices expects argument type(s) (Autodesk.DesignScript.Geometry.Face), but was called with (Autodesk.DesignScript.Geometry.Solid).
Hello, im a university student trying to learn dynamo and ive run into a bit of a problem. Im currently trying generate a parametric roof from my column structure however I keep running into the same error message even when using the testing file youtuber presented.
im really not to sure where to go next as i am quite the beginner at this. Any help would be greatly appreciated.
Read the error message carefully. The node needs a face to work. You have given it a solid. Imagine asking a calculator to divide :honeybee: by :lemon:. It makes no sense to you or the calculator.
Try using this node instead: Topology.Verticies Dynamo Dictionary.
All right thank you ill give that a go. thank you for the quick response.
awhhh your a star thank you that worked like a treat
