Hi everyone,
This is my first post here, so i will try to do it in the right way.!
In the project that i am working on, there is a tunnel, which sections have been design,and placed in revit using adaptive components, taking as reference the alignment points. Above it, a mesh which represent the actual excavation was placed, (the mesh was done using a pointcloud taken with a laser scanner).
So there is a tunnel which represents, let’s say the theorical tunnel, and the real one.
I created a transversal section in a certain point of the alignment, in which you can see the difference between the two tunnel sections, the theorical and the real one. (I add an image showing this)
What i want to know, is, if there is a way to meassure the areas of these two sections, in the view created, in order two make a comparison then between the real and the theorical volume of terrain.
The mesh which represent the real tunnel, is open at the bottom.
Thank you.
