Archi-lab package
Hi guys
I am facing a problem that each time I close the dynamo and open it again, I should search for archi-lab.net package and install again why is that happening ?, any ideas !.
Thank you
Hi @Mohammad_Nawar
Restart your PC. If it didn’t work try downloading custom package from dynamopackages.com and extract the files into your c:\Users\UserName\Appdata\Roaming\Dynamo\1.2\packages folder.
are there any warnings? errors?
Hi @Kulkul
I tried ur suggested solution and it’s not working
Hi @Konrad_K_Sobon
this wt is shows
@Mohammad_Nawar Uninstall all the custom packages and install only archi-lab package.
but also I need the other packages
I just noticed that when I install the package then close the dynamo and revit and open again there is a function that delete the package from c:\Users\UserName\Appdata\Roaming\Dynamo\1.2\packages, Weird !
I had some success setting the installed package folders to read-only
Hi @truevis
Actually this a good idea I will try it and let u know
Thank you
Hi all
For anybody will face this problem in the future, I believe Dyno cause this problem each time I start it the archi-lab.net package disappear, still don’t know why!!! , but I solve it by change the packages reading path for dynamo.
(@truevis your suggestion didn’t work with me.)
Thank you for help
