archi-lab.net package says its already loaded but when I go to the “manage packages” I do not see it there.
Could you show us the packages path?
forgive me but I am really new to dynamo. I am not sure where I would locate the packages path?
see attached screen shot
If you go to that folder path do you see archi-lab folder there? If yes go inside that folder and show screenshot of all the folders and files.
no there is no archi-lab folder there.
Could you manually download archi-lab package from here https://dynamopackages.com/download/53e99ce50e5572016a00018a/2019.2.27 and paste files with archi-lab folder inside that path.
do I unzip the files can copy/paste them to the desired location?
Yes unzip copy/paste to your C:\Users\UserName\appdata\roaming\Dynamo\Dynamo Revit\2.1
once I have copied/pasted them what is the next step?
what do you mean it says it’s already loaded?
Try loading dll file manually. Go to File-> Import Library and select archi-lab packages dll file and open. But before make sure you unblock dll file by right clicking properties. Below is an example:
after I go to import library where to next to find this archi-lab packages dll file?
