Add Rows data to Key Schedule
I’m trying to insert datas into key schedules with dynamo 2.13.1.
My script creates key schedules, add key labels (columns), but i can’t found any way to add datas.
Do you have an idea with packages / nodes or with a python code ?
Thanks a lot
Thanks for your reply but I don’t speak about filtering. My use case is to add some row datas by dynamo. My datas come from a database and I want to add thoses datas into my key schedules like this :
In english it meanings “insert row datas”.
Sorry I misunderstood. Maybe this will help you…
clr.AddReference("RevitAPI")
schedule = UnwrapElement(IN[0])
sched = ViewSchedule.GetTableData(schedule)
sched = TableData.GetSectionData(sched, 1)
TableSectionData.InsertRow(sched, 1)
Hi, I tried but here for me I couldn’t
because my table does not allow it, I must be in the exceptions
as the saying goes, if you can’t do it in revit, you probably can’t do it in dynamo
sched = schedule.GetTableData()
tsd = sched.GetSectionData(SectionType.Header)
tsd_1 = sched.GetSectionData(SectionType.Body)
tsd.InsertRow(tsd.FirstRowNumber)
a= tsd.CanInsertRow(1)
b= tsd_1.CanInsertRow(1)
OUT = a,b
cordially
christian.stan
Not sure about that. I am just getting into python and the API, so my code looks rudimentary. I utilized some of your approach and revamped my code. It works the same, but does look neater.
sched = sched.GetSectionData(SectionType.Body)
sched.InsertRow(1)
You are right, your code is cleaner :wink:.
with your code: :+1:
I’m trying my hand at the API too, I hope you didn’t take my message the wrong way (that wasn’t the goal) I was trying on a legend whose body wasn’t changeable (so it doesn’t help)
cordially
christian.stan
Not at all. I welcome any and all guidance. I was just happy that I could figure it out in the first place. Glad you figured out why it wasn’t working for you. It’s good to know that sort of stuff, so thanks for sharing.
I went ahead and threw in a schedule checker and counter loop to add multiple rows. I haven’t messed with Key schedules in Revit, so not sure if this will help or not.
Thanks a lot ! I will check as soon as possible. But I ve just a question : where is the datas inserted. I can see you’re using a method to “insertrow” but I can’t see where the value is inserted too.
Look at Key Schedule node from archilab. That should let you populate your schedule with the data. Also take a look at the posts below. They provide some additional information. There may be other posts about this subject in the forum also.
