I have created a schedule in Revit and i just want to select that view in Dynamo and read the data as strings, so it gives me nested lists of each of the columns/rows in the schedule. I know I can return the elements but i want the entire table of information as it has been filtered and sorted. Any ideas?
Hi Mark
You’ll need Python / Revit API. I believe there is a package that does this too but not sure which so maybe someone else on the forum can point you in the right direction.
I use this python script…next time, I’ll need to invoice you
If you use filters, this script will simply pick up the data thats visible
#Copyright 2016. All rights reserved. Bimorph Consultancy LTD, 5 St Johns Lane, London EC1M 4BH www.bimorph.co.uk
#Written by Thomas Mahon @Thomas__Mahon info@bimorph.co.uk
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
schedule = UnwrapElement(IN[0])
# "Start" the transaction
#count the number of rows and columns in the schedule
table = schedule.GetTableData().GetSectionData(SectionType.Body)
nRows = table.NumberOfRows
nColumns = table.NumberOfColumns
#Collect all of data from the schedule
dataListRow = []
for row in range(nRows): #Iterate through the rows. The second row is always a blank space
dataListColumn = []
for column in range(nColumns): #Iterate through the columns
dataListColumn.Add( TableView.GetCellText(schedule, SectionType.Body, row, column) )
dataListRow.Add( dataListColumn );
# "End" the transaction
OUT = dataListRow
Haha cheers Tom, I thought I had seen a node in someones package that did it.
This is great. Thanks for sharing. I would just have two small comments:
you don’t need a Transaction for this as you are not creating anything but merely reading a data in a ViewSchedule
You don’t need a ProtoGeometry import since you never use any methods from that library.
Also, @Mark_Thorley1 as an alternative, and I am not sure what you want to do with the data, but if you want to take the data and write it out to Excel, you can do this:
# Copyright(c) 2016, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Import Element wrapper extension methods
# Import RevitAPI
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
def ProcessList(_func, _list):
return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def Unwrap(item):
return UnwrapElement(item)
if isinstance(IN[0], list):
schedules = ProcessList(Unwrap, IN[0])
schedules = [Unwrap(IN[0])]
directory = IN[1]
def ExportSchedule(schedule, dir = directory):
options = ViewScheduleExportOptions()
# there are couple of options that can be set here:
# ColumnHeaders: options are None, OneRow and MultipleRows
options.ColumnHeaders = ExportColumnHeaders.MultipleRows
# FieldDelimiter: input is a string. By default Tab is used
options.FieldDelimiter = ","
# HeadersFootersBlanks: if you want to export blank headers and footers just set it to True
options.HeadersFootersBlanks = True
# ExportTextQualifier: how to identify text fields. Options are None, Quote or DoubleQuote
options.TextQualifier = ExportTextQualifier.DoubleQuote
# Title: set to True if you wish to export it.
options.Title = True
schedule.Export(dir, schedule.Name + "_export.csv", options)
try:
errorReport = None
ProcessList(ExportSchedule, schedules)
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
#Assign your output to the OUT variable
if errorReport == None:
OUT = schedules
OUT = errorReport
Result when you import it into an Excel would be this:
This is a method that is available in API for exporting ViewSchedules directly to CSV, TSV or any other delimited text files. Hope this helps!
Cheers!
@Konrad_K_Sobon nice one, appreciate the tips!
