clr.AddReference("RevitAPI")
clr.AddReference("System")
Topo = UnwrapElement(IN[0])
Points = UnwrapElement(IN[1])
output = []
try:
Topo.AddPoints(pyPoints)
except Exception,e:
output.append(str(e))
OUT = output
Thanks for your reply.
The image in the post you linked to won’t show in my browser, hence I was not able to understand what was changing.
I think I have to change the list of python points to another list format for c#?, but unsure what the code line would look like. Any help would be appreciated
As mentioned in the post lower down, recreating the topo with the new points included is your only likely way to go from Dynamo… This would need to recreate any edits such as regions.
