In Python 3 inside Dynamo for Revit 2023 I am trying and failing to erase all the interior points inside a Toposurface using Python. My script goes as follows:
# Import necessary CLR assemblies and references
clr.AddReference('RevitAPI')
# Import Revit API namespaces
from Autodesk.Revit.DB.Architecture import *
# Import RevitNodes to allow for Dynamo & Revit type conversions
# Import RevitServices for Document and Transaction management
# Define a custom failure processor by implementing the IFailuresPreprocessor interface
class CustomFailureProcessor(IFailuresPreprocessor):
def PreprocessFailures(self, failuresAccessor):
# Ignore all failures for simplicity
failures = list(failuresAccessor.GetFailureMessages())
for failure in failures:
failuresAccessor.DeleteWarning(failure)
return FailureProcessingResult.Continue
# Get the current Revit document from the Document Manager
# Assuming the input is a topography surface element wrapped in Dynamo
topoSurface = UnwrapElement(IN[0]) # Unwrap the Dynamo element to get the Revit element
# Get the interior points of the topography surface
interiorPoints = topoSurface.GetInteriorPoints()
# Begin a transaction to modify the document
# Define a scope for editing the topography, required for certain operations
topoEditScope = TopographyEditScope(doc, "Edit Topography Scope")
topoEditScope.Start(topoSurface.Id)
try:
# Perform the operation: Delete interior points from the topography surface
topoSurface.DeletePoints(interiorPoints)
doc.Regenerate()
finally:
# Always ensure to close the TopographyEditScope properly
topoEditScope.Commit(CustomFailureProcessor())
# End the transaction
# Output the number of deleted points for verification
OUT = len(interiorPoints)
However I get the error “InvalidOperationException”: This TopographyEditScope is not permited to start at this moment for one of the possible reasons: The document is in read-only state, or the document is currently modifiable, or there already us another edit mode active in the document. And ok, I get it, I am already opening a transaction. However if I access the TopographyEditScope without the TransactionManager.Instance.EnsureInTransaction(doc) it says I need a previous transaction for the TopographyEditScope to start. Grouping the transactions does not seem to be working either. Has anyone solved a similar issue?
R23_TopographyEditScope.dyn (6.5 KB)
@luisaECXV3 ,
here your clean code, at first view looks like AI generated and evaluated by a real brain. So i would not open a transaction in a transaction.
clr.AddReference("RevitAPI")
clr.AddReference("ProtoGeometry")
# 0️⃣ Define a custom failure processor by implementing the IFailuresPreprocessor interface
# 💤 Ignore all failures for simplicity
# 1️⃣ Assuming the input is a topography surface element wrapped in Dynamo
# 2️⃣ Get the interior points of the topography surface
# 🔓 Begin a transaction to modify the document
topoEditScope = TopographyEditScope(doc, “Edit Topography Scope”)
try:
doc.Regenerate()
finally:
# 🔒 End the transaction
# ✅ Output the number of deleted points for verification
i can not replicate your topic directly. will see what others write…
t = Transaction(doc, "Edit Topography Scope")
t.Start()
topoEditScope = TopographyEditScope(doc)
try:
doc.Regenerate()
except:
t.Commit()
KR
Andreas
First, thank you very much for replying, Andreas. So, I tried following the steps you mentioned for setting up the transactions, but for some reason, the DeletePoints method still isn’t playing ball. I went back, double-checked everything, and even swapped TopoSurface for Topography , making sure to pack the interior points into an IList since that seemed to be what DeletePoints was looking for. But, guess what? Those points are still there, as if they’re mocking me. I even went the extra mile to make sure they were actually gone, but no luck. So, what gives? Is the DeletePoints method just messing with me, or am I missing something obvious here?
R23_TopographyEditScope_V2.dyn (7.2 KB)
R23_Topo.rvt (4.4 MB)
# Add .NET collections import
# Getting the topography with a Filter. At first I tried getting the Toposurface directly and this gave me nothing, so new approach:
topoSurfaces = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Topography).ToElements()
interiorPoints=[]
# Get the interior points of the topography surface and delete them
for topoSurface in topoSurfaces:
pythonList = topoSurface.GetInteriorPoints() # This gets the points as a Python list
# Convert Python list to .NET IList[XYZ]. Realized this method needed an IList. Still not working anyway.
interiorPoints = List[XYZ](pythonList)
t.Start()
topoEditScope = TopographyEditScope(doc, "Topo")
try:
# Perform the operation: Delete interior points from the topography surface, this is what is not working and I can't guess what the problem is
topoEditScope.Start()
doc.Regenerate()
topoEditScope.Commit()
except Exception as e:
OUT = e
topoEditScope.Dispose()
finally:
t.Commit()
newTopoPoints=topoSurface.GetInteriorPoints()
# Doble checking. Still no points deleted
OUT = pythonList,newTopoPoints, topoSurfaces
Can you send a link to which method you are attempting to use? I believe that delete points is a member of the TopographySurface class, not topographies in general.
Also I find it best to build your initial functions without a ‘try’ as it masks the errors which pop up. I would guess this is what you are seeing as you set OUT to the exception, but then later on redefine it as something else, thereby masking the exception entirely.
Of course. This is the method I am attempting to use DeletePoints Method it is indeed a TopographySurface Method, but so is GetInteriorPoints(), which is working correctly. When I remove the try and except like this:
interiorPoints=[]
t.Start()
doc.Regenerate()
t.Commit()
I get the error: “TopographyEditScope is not permitted to start at this moment for one of the following possible reasons: The document is in read-only state, or the document is currently modifiable, or there already is a topography surface edit mode active in the document.” Obviously the document is being edited, we started a transaction here. But if I remove the document transaction like this:
interiorPoints=[]
doc.Regenerate()
then I will get “Attempt to modify the model outside of transaction.” The topography edit scope documentation is here TopographyEditScope Constructor
Perhaps the solution would be to attempt to use a transaction group but this is still giving me the same problems.
