Hi, I am attempting to make a simplified version of http://learndynamo.com/mod2/ creation of building elevations. At this point I am not versed enough in Python to fully utilize this script.
Therefore, I have gone through VS and tried to figure out what method to use. I’m almost there I think, but I cannot convert the Dynamo point object to a Revit with the ‘To.Xyz()’ method.
Is it possible that this is failing because I did not import the correct libraries? I think i did.
# Enable Python support and load DesignScript library
# wrapping and unwrapping Revit Elements
clr.AddReference('RevitAPI')
toggle = UnwrapElement(IN[0])
pt = UnwrapElement(IN[1])
viewId = UnwrapElement(IN[2])
#output = []
#create Revit Point facsimile
elevPt = pt.ToXyz()
# assign current document
if toggle == True:
collector = FilteredElementCollector(doc, doc.ActiveView.Id)
elevation = ElevationMarker.CreateElevationMarker(doc, viewType, elevPt, 100)
OUT = elevation
