Adaptive family placement with points from a curve
I am placing adaptive family on the points created from a curve.
“Party breaker” appears with defining the side point. Points are changing side of the curve I assume that is connected to the vector but I do not know how to solve it.
Any ideas how to put all the points on one side?
Best Regards,
Adnan![Adaptive%20Dynamo_2|690x384](uplAdoptive_points_0.0.6.dyn (184.3 KB)
BOX Rotation_v5.rvt (2.3 MB)
oad://jc9IvkvEZM7vAdd9cbAArLb95Bh.jpeg)
Drop here rvt file.
added to first post.
There is some info on something similar here:
But it may be a completely different issue, depending on the number of control points in your family :thinking:
Can’t check the rvt out until tmw though.
@adnandj @Ewan_Opie If the vector is negative you see this kind of behavior. Try this Adoptive_points_0.0.6(For Adnan).dyn (217.1 KB)
Hi Kulkul,
thank you!! But as always this is good but I have a problem appears when geometry is not ideal. I am sending you the Revit file…
Adaptive%20Revit_3
BOX Rotation_v6.rvt (2.0 MB)
Looks like you may want a 3rd point in your family so you can specify the vertical axis on placement.
I have already three points inside and the third point is creating couple of problems…
