Hi everyone!
Have you got any idea how the “adaptive components by paramaters on curve” node works? I feel lost dealing with the parameters.
Have anybody got a easy understood exemple to share?
Thanks you !
Hi everyone!
Thanks you !
You can re-work sample 18 Adaptive components to use the AC by Parameters node like this, although it isn't quite as useful in this example:
This particular example really is more appropriate for "by XYZ", although the image above should give you a start for how to use this node.
Also, check out the test samples for AC functionality here:
https://github.com/ikeough/Dynamo/tree/master/test/revit/AdaptiveComponent
