Hi all,
When I select an adaptive component in Revit and create a curve in Dynamo from it, the geometry in Dynamo is not correct.
In the simple example below I’ve created an Adaptive Component family consisting of two points and a line between them and inserted the family in a conceptual mass in Revit.
When I select the elements in Dynamo and create element curves from them, the curves are in wrong positions. When I look at the Adaptive Components Location Points they are in the correct place. Is this a bug or am I doing something wrong?
Best regards,
