I use rhynamo to get a rhino model in dynamo, however this is something wrong with it ,and i can’t handle it. Is there someone else meet the problem , or someone who can help me ,thanks.
warning: can’t find the function named Translate (at Autodesk.DesignScript.Geometry.Mesh , use _array,double,double,double)
Hi Vincent,
Can you show watch node after “RhinoTranslationToDS.Rhino.Rhino_MeshToDS”. Are you getting polysurface?
You will need to convert Mesh to polysurface. Have a look at Dimitar’s reply at this post Rhino mesh to Revit mass form
Hi Kulkul,
Thanks,however it seems that it doesn’t work.
Can you drop here rhino file?
Did you try the other node called “RhinoTranslationToDS.Rhino_BrepsToDS” that will give you polysurface then you can use “Solid.ByJoinedSurfaces” to convert to solid.
new users can not upload attachments…
i’ll try tomorrow. Thank you .
You can drop file in dropbox and drop the link here.
The model is baked from grasshopper
