I am brand new to Dynamo and am trying to establish a workflow between Revit to Rhino using Rhynamo. I’ve been following a simple component string or file -> file from path-> OpenRhino -> GetDocumentObjects -> TranslateRhinoExtrusion. After completing this wire, I get a run error as follows:
“Warning: RhinoTranslationToDS.Rhino_ExtrusionToDS operation failed.
Method not found: ‘Autodesk.DesignScript.Geometry.PolyCurve Autodesk.DesignScript.Geometry.PolyCurve.ByJoinedCurves(System.Collections.Generic.IEnumerable`1<Autodesk.DesignScript.Geometry.Curve>)’”
I have downloaded the latest Dynamo and Dynamo Core builds:
I am using Revit 2019 but also have Revit 2015, 2017 2018 installed onto my computer. I’ve tried a work around I found on this forum that uses microsoft fixit to clear my computer of any Dynamo core files and reinstalled a fresh up to date version of Dynamo but I am still getting this error message. Any other options to try?
Thanks!
Alex
