3.2->3.3 Update broke script
Hello
I updated civil3d today, and with that a new Dynamo was installed. Dynamo core went from 3.2 to 3.3, and made multiple components over the script throw errors, specifically in regards to points being coincident. Did something change in that patch?
Hi @mpH2G37,
Are you able to share the DYN, and possibly even a DWG? You can send me a DM if needed.
Hi. After many trials and erros, It looks like when updating, the workspace geometry scaling gets reset. My file currently has points setup that are far from the origin (where the modeling is happening), which leads to a very spread out geometry. After temporarely removing the points, and setting the scale to medium, the dynamo file now works. I am baffled by the fact that small scale calculations, can sometimes straigh up not work, when the geometry is too spread out.
