I’m new to Dynamo, and used only someone’s else code, which is not ideal but works 50% of time, so if you will find silly mistakes it is because of that.
I found a dynamo code to write room parameter value into the leements within it but ONLY if those rooms are in the same model as element. SO I used it as base for the code here.
I get a help to collect and transform the linked rooms into Revit Rooms. But they keep showing Null and Empty List then I make Element.Solid out of it (I tried Orchid and Revit original Solid Node) - both has same problem.
I tried to get rid of nulls and empty lists by boolmask, which you can see.
I manage to get rid of nulls, but once connected to Solid.ByUnion it is result Warning
I will attach the code, so if you have a time please look at it as well.
Room Number from Link to Elements.dyn (65.7 KB)
Thank you for any advices!
