Write parameter from circuit to cable
Hello
I try to write a shared parameter from my circuit to my wire, because i wants to lable it to the wire.
Not every circuit has a cable so i has to filter my circuits. but i didnt get in in Dynamo to work.
The Parameters “Panel” and “Circuit” has to be the same on the circuit and the wire. If this is true i’d like to write the parameter from the Circuit to the Wire.
I startet with this to collect the used parameters, and tryed different ways to filter, but nothing worked well.
I hope somebody can give me a hint :slight_smile:
You don’t need to get the Designation values right away. Get your Panel and Circuit parameters so you can sort your elements first. Then, once everything is sorted, you can get the Designation of the circuit elements and plug that right into the wire elements.
Hey Nick
Thank you verry much. Your solution did exactly what i want.
Especially this point to combine two lists, helped me out.
:slightly_smiling_face:
