hello
I want to copy the name of a circuit and copy it into a shared parameter. my dynamo doesn’t work I can’t understand where the problem is
if someone could help me a little
Hi @seb-fr-37 ,
We can’t read the node names, could you re-upload your screenshot? Also, could you share what the error message is from the SetParameter node? It probably has something to do with a wrong value type, the error messages often give you a clue in the right direction.
Maybe it’s a type parameter?
Use a element.parameter node to check the parameters of the family types and also of the family instaces.
thanks it s work
