In a previous post, linked here, I presented my problem. What I’m basically doing is running a solar analysis on an hourly basis over one year.
After looking further into the issue, I found out that SolarAnalysis.Analyze has a limit of 11 hours.
If I choose a date with more than 11 hours of sunlight, the output stops at the end of the eleventh hour.
Now, of course, I can do this manually but this is going to take some time as I have to change the sun settings in Revit, run the process and wait for it to finish and repeat. And for days with more than 11 hours of sunlight, I will have to split the output in 2.
Any idea how to overcome this limitation?
Thanks.
P.S.
Since the previous post, I altered my graph so I’m attaching the modified graph. The “filename” node on the right is a custom node I created to automatically create the output filename by using the study date.
