I am having an error message when running Solar Analysis in Dynamo and Revit. The warning message is: “One or more of the input types are not matching. Couldn’t find a version of Analyze that takes arguments of type (System.Object,_array,_array,DynamoSolarAnalysis.Analysis.TimeStudy,int,double)”.
When I disconnect either one of the surface node, the message disappear. However, there is no result at the Cumulative and Average watch nodes.
Thank you very much for the suggestion. I have flatten the Shading Surfaces and changed the weather file from epw to wea. It’s working now.
I have another question, do you know how to get daily data from Solar Analysis? For example, I run the simulation from 1st to 31st of May, but the output show average and cumulative values. How to get the value on each day. Attached herewith the print screen.
as far as i am aware you cant get daily values out directly.
one way might be to input multiple timeStudy (one for each day) and then that should give you list of results per timestudy
