When I use WombatDynamo package Wall.ByProfile, get a warning message, “Could not load type ‘Autodesk.Revit.DB.SpecTypeId’ from assembly ‘RevitAPI, Version=18.0.0.0, Culture=neutral, PublicKeyToken=null’.”
How can I fix it?
Revit 2018, Dynamo 2.04
Hi @deg_zx,
This WombatDynamo package’s version seems updated fro Revit 2022 and Revit 2023.
You must use an older version of the WombatDynamo package.
Now I am using WombatDynamo 2.3.5, so I should back to 1.3.* ?
Look at the release dates of the packages and test with the one that makes sense to you. (before the release of Revit 2022)
Thanks for all, I’ll give it a try.
