Erro no Dynamaps
No meu aparece o seguinte erro, no momento que aperto push to Dynamo: Não foi possível carregar o tipo Autodesk.Revit.DB.DisplayUnitType do assembly RevitAPI, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null. O que pode ser, o pacote está desatualizado? Alguém pode me ajudar, por favor.
Minha versão do Dynamo core 2.10.1.3976 e Dynamo Revit 2.10.1.4002
Minha versão do Revit é 2022 22.0.2.392
Translated by moderator:
The following error does not appear when I open push to Dynamo: It was not possible to load the type Autodesk.Revit.DB.DisplayUnitType of assembly RevitAPI, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null. Or what could it be, or is the package outdated? Can someone help me, please.
Minimum version of Dynamo core 2.10.1.3976 and Dynamo Revit 2.10.1.4002
Minha version of Revit is 2022 22.0.2.392
Hi
The forum language is English. To get help and make it possible to do search you need to use English in your posts.
Use google translate to translate and we will be able to help you if you’re not common in to write in english
Ok friend, thanks for the tip, I hadn’t tried that.
In mine, the following error appears, when I press push to Dynamo: It was not possible to load the type Autodesk.Revit.DB.DisplayUnitType from the RevitAPI assembly, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null. What can it be, is the package outdated? Can someone help me please.
My version of Dynamo core 2.10.1.3976 and Dynamo Revit 2.10.1.4002
My Revit version is 2022 22.0.2.392
Translated by the moderator:
The following error does not appear when I push to Dynamo: Unable to load type Autodesk.Revit.DB.DisplayUnitType from RevitAPI assembly, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null. Or what could it be, or is the package out of date? Can someone help me please.
