Winform Listbox ordered selection
I am trying to create a dialog window using Winform, that would give me a list of sorted parameter names selected in order from a given list. Basicaly I would like to have two windows, first showing the list of all parameters and the second showing the selected. When I doubleclick on a parameter from the first list, it moves to the second list, that is correct. But what I cant do is to remove the item from the second list after again doubleclicking on it back to the list 1. I always get this error : *List that this enumerator is bound to has been modified. An enumerarot can only be used if the list does not change*. I get the same error when I try to remove selected item from the first list. Can anyone help?
Thank you, L.
import sys
pyt_path = r’C:\Program Files (x86)\IronPython 2.7\Lib’
sys.path.append(pyt_path)
clr.AddReference(“System.Windows.Forms”)
clr.AddReference(“System.Drawing”)
from System.Windows.Forms import *
from System.Drawing import Icon, Color, Font, Point, Size, SolidBrush, Rectangle
from System import Array, Object
import System.IO
titleText = “form”
btnHeight = 30
btnWidth = 200
spacing = 20
fontMessage = Font(“ISOCPEUR”, 8)
fontCK = Font(“ISOCPEUR”, 8)
fontTI = Font(“ISOCPEUR”, 10)
fontEX = Font(“ISOCPEUR”, 7)
def button(txt, loc, clc):
btn = Button()
btn.Text = txt
btn.Anchor = (AnchorStyles.Bottom | AnchorStyles.Right)
btn.Location = loc
btn.Click += clc
btn.Height = btnHeight
btn.Width = btnWidth
btn.BackColor = Color.FromArgb(255, 255, 255)
return btn
def tolist(obj1):
if hasattr(obj1,“iter”): return obj1
else: return [obj1]
class dimsionInputs(Form):
def __init__(self,args1):
	self.Text = titleText
	self.BackColor = Color.FromArgb(240, 240, 240)
	self.WindowState = FormWindowState.Normal
	self.CenterToScreen()
	self.BringToFront()
	self.Topmost = True
	self.Width = 600
	self.Height =950
	self.FormBorderStyle = FormBorderStyle.FixedDialog
	userMessage = Label()
	font = fontMessage
	userMessage.Text = 'text'
	userMessage.Font = fontTI
	userMessage.Location =Point(50,20)
	userMessage.Width = 500
	userMessage.Height = 50
	self.Controls.Add(userMessage)
LIST 1 - parametry
	self.checklistLabel = Label()
	self.checklistLabel.Text = "text"
	self.checklistLabel.Width = 120
	self.checklistLabel.Location = Point(50,70)
	self.checklistLabel.Height = 50
	self.Controls.Add(self.checklistLabel)
	self.checkval = []
	self.output1 = []
	self.Font = fontCK
	self.list1 = ListBox()
	self.list1.Size = Size(350,300)
	self.list1.Location= Point(180,70)
	array = Array[Object](args1)
	self.list1.Items.AddRange(array)
for i in args1:
self.list1.Items.Add(i)
	self.list1.MouseDoubleClick += self.btn_Click
	self.Controls.Add(self.list1)
	self.AutoScroll = True
LIST 1 - vybrané parametry
	self.list2 = ListBox()
	self.list2.Size = Size(350,300)
	self.list2.Location= Point(180,420)
	self.list2.MouseDoubleClick += self.btn_Clickbck
	self.Controls.Add(self.list2)
OK AND CANCEL BUTTONS
	btnOkClick = self.update
	btnOkLoc = Point(50,830)
	btnOk = button('OK', btnOkLoc, btnOkClick)
	btnCnclClick = self.CnlButtonPressed
	btnCnclLoc = Point(330,830)
	btnCancel = button('Cancel', btnCnclLoc, btnCnclClick)
	self.Controls.Add(btnOk)
	self.Controls.Add(btnCancel)
def btn_Click(self,sender, event):
	for item in self.list1.SelectedItems:
		self.list2.Items.Add(item)
def btn_Clickbck (self,sender, event):
	for item in self.list2.SelectedItems:
		self.list2.Items.Remove(item)
def update(self, sender, event):
	self.output1 = form.list2.Items
	self.Close()
### buttons ###
def okButtonPressed(self, sender, event):
self.output1 = self.checkbox.SelectedItem
	self.Close()
def CnlButtonPressed(self, sender, event):
	self.Close()
if IN[0] == None: l1 =
else: l1 = tolist(IN[0])
form = dimsionInputs(l1)
Application.Run(form)
OUT = form.output1
Application.Exit()
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
clr.AddReference("System.Windows.Forms")
clr.AddReference("System.Drawing")
import System.IO
titleText = "form"
btnHeight = 30
btnWidth = 200
spacing = 20
fontMessage = Font("ISOCPEUR", 8)
fontCK = Font("ISOCPEUR", 8)
fontTI = Font("ISOCPEUR", 10)
fontEX = Font("ISOCPEUR", 7)
	btn = Button()
	btn.Text = txt
	btn.Location = loc
	btn.Click += clc
	return btn
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
		self.BringToFront()
		self.Topmost = True
		self.Width = 600
		self.Height =950
		font = fontMessage
## LIST 1 - parametry ##
		self.checkval = []
		self.output1 = []
		self.Font = fontCK
#		for i in args1:
#			self.list1.Items.AddRange(Array[i])
#		for i in args1:
#			self.list1.Items.Add(i)
## LIST 1 - vybrané parametry ##
## OK AND CANCEL BUTTONS ##
		self.Close()
	### buttons ###
#		self.output1 = self.checkbox.SelectedItem
		self.Close()
		self.Close()
if IN[0] == None: l1 = []
OUT =  form.output1
Application.Exit()
Apologies for a bad formatting :frowning:
@Lucy_Lastparametrics this is what you need:
Winform.dyn (9.1 KB)
		while len(self.list1.SelectedItems) > 0:
			self.list1.Items.RemoveAt(self.list1.SelectedIndices[0])
		self.list2.Sorted = True
			self.list1.Items.Add(item)
		while len(self.list2.SelectedItems) > 0:
			self.list2.Items.RemoveAt(self.list2.SelectedIndices[0])
		self.list1.Sorted = True
