Winforms with dynamo
Good day dears,
i’m trying to learn winforms using python in dynamo to achieve project idea.
the idea that i have 2 inputs:
  • one with changed number values … here in this example i use days name, i shall choose from them using CheckBox
  • the other one with 2 constant value like true false … here in this example i use ( week1, week2), i shall use Radio Button to choose between them
the output must be 2 list , the result from 2 inputs
i have tried to do it , but it keeps give warnings
if anybody could help please
the window should be somthing like this , but with one button
radiobutton
the code :
  clr.AddReference("System.Windows.Forms")
  clr.AddReference("System.Drawing")
  from System.Windows.Forms import Application, Form, StatusBar
  from System.Windows.Forms import RadioButton, GroupBox, CheckBox, Label,
  Button, AnchorStyles, DockStyle, PictureBox, PictureBoxSizeMode, TextBox
  from System.Windows.Forms import TrackBar, TickStyle
  from System.Drawing import Size, Point, Font, Color, Image
in1 = IN[0]
class IForm(Form):
def __init__(self):
	self.checkval = []
	self.output1 = []
	self.output2 = []
	self.Font = Font("Arial",12)
	self.BackColor = Color.White
	self.label = Label()
	self.label.Text = "Choose"
	self.label.Location = Point(25, 100)
	self.label.Height = 25
	self.label.Width = 225
	self.label.Font = Font("OpenSans",12)
	j=150
	for i in range(len(in1)):
	   self.checkbox = CheckBox()
	   self.checkbox.Text=in1[i]
	   self.checkbox.Location = Point(25,j)
	   j+=25
	   self.checkbox.Width = 200
	   self.checkbox.Font= Font("OpenSans",10)
	   self.Controls.Add(self.checkbox)
	   self.checkval.append(self.checkbox)
	self.button1 = Button()
	self.button1.Text = 'apply and close'
	self.button1.Location = Point(25, j+50)
	self.button1.Click += self.update
	self.button1.Width = 250
	self.AcceptButton = self.button1
	self.Controls.Add(self.label)
	self.Controls.Add(self.button1)
	self.CenterToScreen()
	self.AutoSize = True
	gb = GroupBox()
    gb.Text = "Week"
    gb.Size = Size(120, 110)
    gb.Location = Point(20, 20)
    gb.Parent = self
    week1 = RadioButton()
    week1.Text = "Week 1"
    week1.Parent = gb
    week1.Location = Point(10, 30)
    week1.CheckedChanged += self.OnChanged
    week2 = RadioButton()
    week2.Text = "week2"
    week2.Parent = gb
    week2.Location = Point(10, 60)
    week2.CheckedChanged += self.OnChanged
def OnChanged(self, sender, event):
    if sender.Checked:
       self.output2.append(sender.Text)
def update(self, sender, event):
	for f in self.checkval:
	    self.output1.append(f.Checked)
	self.Close()
form = IForm()
Application.Run(form)
OUT = form.output1, form.output2
Dear @erfajo ,
that’s a good advises i should follow and take , really appreciate for your help
thank you
maybe that will answer your questions:
http://www.voidspace.org.uk/ironpython/winforms/
thanks you @Peter_Kompolschek
this website is addition useful source to learn from
have you taked a look in this dynamo packaged?
