Windows room location Clockwork
Hi everyone,
First of all, Im very happy for the Clockwork node - Room.Windows - it helps me a lot in my work. As it is described it retreives all windows associated with a room, but as I can see only windows placed in a wall or a roof. I have this situation where a window works like a curtain wall. Those wont get retreived I surpose. I dont dont do the modelling, I retreive the models and extract data. Any ideas how to capture this window here?
Skærmbillede 2024-05-21 155832
Thanks!
Any window that has a room calculation point located inside the room will be retrieved. Doesn’t matter what it’s hosted on. I need to change that node description, I guess.
For QA purposes I would recommend checking if the window families in the model have a room calculation point and otherwise abort the script and have the user fix the families first.
Hi Andreas,
Thanks for det reply. Well its good news, that your node is using calculation point. I had to fix the families, and now it works. Thank you!
