HELLO ALL
I need all the fittings which are generated using “MEPFitting.ByMEPCurves” Node.
why can’t i get all fittings as output instead of “fitting not created by dynamo”?
DO I NEED TO CHANGE THE PYTHON.?
PLEASE SUGGEST!
THANK YOU IN ADVANCE.
HELLO ALL
PLEASE SUGGEST!
I’m guessing this either means Dynamo ran into an error and didn’t create the fitting or a fitting was created by auto-routing in Revit and not directly by the Dynamo node.
Dynamo Created the fittings. (48 fittings) but the complete output has not come.
we got few fittings and remaining as Fitting not created by Dynamo.
I need complete fitting ID’s which are generated.
48 fittings as result.
Thank you.
As @Nick_Boyts mentions: The fitting are created by auto-routing in Revit. Sadly there is no way to get them to show up in Dynamo.
Perhaps gather the associated fittings before the execution and join the created fittings with the previously created fittings?
Or grab the entire system after the run. Kinda depends on the scope of your “new” pipe fittings.
