When I do “Export for Generative Design” and click “CreateStudy”, the window closes immediately.
The size of .dyn used by Generative Design is 86.1MB.
There is a lot of data stored in Data.Remember, but it is a necessary amount for many studies.
Sure, I think it’s too big for a Dynamo file, but is this the cause?
By the way, I use Refinery 0.62.20, Dynamo for Civil 3D.
Hi Oh_ruki,
Thanks for reporting this. You are running a now very old version of Generative Design, would it be possible for you to upgrade to the current release by working with the Autodesk person who helped you set it up?
If this is not possible, please let us know. We have fixed a lot of bugs since 0.62.20 and this may be one of them.
Thanks,
Neal, for the Generative Design team.
It’s impossible because I set it up by myself.
Neal, can you help me?
Hi oh_ruki,
Are you able to get access to and install Revit 2021? The most recent updates for Generative Design are only available with Revit 2021.
Thanks,
Neal
Hi Neal,
With Revit2021 installed and the latest version of Generative Design,
I was able to open .dyn, which I couldn’t open before.
Thank you very much.
Hi Oh_ruki,
Thanks for updating us with that information. Just to be clear, did you copy the relevant GD packages around to get it to work?
Thanks for letting us know,
Neal
Hi Neal,
Yes, I copied the related packages to the package storage folder of each app and it worked.
I’m sorry to hear from this post,
Will it be copied again each time GD is upgraded?
Hi Oh_ruki,
Thanks for letting us know. We will get back to you with how to proceed going forward.
Best,
Neal
