What is the built-in category of Structural Connections in Revit API?
what is the built-in category of Structural Connections in Revit API? something like OST_StructuralConnection does not exist for example
@RubenVivancos ,
maybe you can change the methode how to get these Elements… here an example:
clr.AddReference('RevitAPI')
clr.AddReference('System')
filter_columns = ElementStructuralTypeFilter(StructuralType.Column)
filter_Braces = ElementStructuralTypeFilter(StructuralType.Brace)
filter_nonStruc = ElementStructuralTypeFilter(StructuralType.NonStructural)
filter_footing = ElementStructuralTypeFilter(StructuralType.Footing)
filter_unknown = ElementStructuralTypeFilter(StructuralType.UnknownFraming)
filter_beams = ElementStructuralTypeFilter(StructuralType.Beam)
all_columns = FilteredElementCollector(doc).WherePasses(filter_columns).WhereElementIsNotElementType().ToElements()
all_Braces = FilteredElementCollector(doc).WherePasses(filter_Braces).WhereElementIsNotElementType().ToElements()
all_nonStruc = FilteredElementCollector(doc).WherePasses(filter_nonStruc).WhereElementIsNotElementType().ToElements()
all_footing = FilteredElementCollector(doc).WherePasses(filter_footing).WhereElementIsNotElementType().ToElements()
all_unknown = FilteredElementCollector(doc).WherePasses(filter_unknown).WhereElementIsNotElementType().ToElements()
all_beams = FilteredElementCollector(doc).WherePasses(filter_beams).WhereElementIsNotElementType().ToElements()
OUT = all_columns, all_Braces, all_nonStruc, all_footing, all_unknown, all_beams
OST_StructConnections
thanks, I did not see this. also can be resolved by using the category Id alternatively:
collector = FilteredElementCollector(doc, view.Id).OfClass(FamilyInstance).WherePasses(ElementCategoryFilter(ElementId(-2009030)))
