Get All Elements Of Category
Hi everybody. How can I write the problem of getting the elements of figure 1 as shown in Figure 2. Help me. Thanks
Some thing like that
for cat in cats:
    bic = System.Enum.ToObject(BuiltInCategory, cat.Id.IntegerValue)
    filter =FilteredElementCollector(doc).OfCategory(bic).ToElements()
    ls.append(filter)
OUT = ls
Thank you very much. However, when I try to compose the code like your example, I get an error as shown
Check the library import again, maybe it is not enough.
#Copyright(c) 2021, Hồ Văn Chương
# @chuongmep, https://chuongmep.com/
clr.AddReference('RevitAPI')
clr.AddReference('System')
import System
import sys
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
app = DocumentManager.Instance.CurrentUIApplication.Application
ls = []
cats = doc.Settings.Categories
for cat in cats:
    ls.append(filter)
OUT = ls
#Do Action
OUT = ls
import System
# Current doc/app/ui
#Filtered element collector
fram = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralFraming).WhereElementIsNotElementType().ToElements()
OUT = fram
a = Revit.Category.ByName("StructuralFraming");
ElementQueries.OfCategory(a);
