Elements of Subcategory
I am trying to get the elements from the Girder subcategory but it’s not working.
Hi, they are visible when you use the category Structural Framing, dont select the sub category
The following Python Code should work for you:
#Created By Brendan Cassidy
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
girderFilter = StructuralInstanceUsageFilter(StructuralInstanceUsage.Girder)
OUT=[]
for g in FilteredElementCollector(doc).WherePasses(girderFilter):
	OUT.append(g.ToDSType(False))
