why is it that the node Element.GetParameterValueByName since now reports a link to the value “revit ID” and no longer reports the value??
and most importantly why is the behavior changed and what is it good for?
( iam using a daily build from aug 20th)
stepped back to an older release… everything fine & running smoothly
Hi Peter, if you see this again, can you attach the dyn file? I just tried this out on the daily build from today (28 August), and it seems to work fine.
hi colin, it is odd. the code is one time working fine the other time it is giving a null result.
