I am trying to use the Solar Analysis Weather.FromFile node in dynamo but I am getting the following error. “Warning: Weather.FromFile operation failed. The specified weather file does not contain any data.”
In theory this node should take a the file path to a .wea weather file and then allow it to be used in the solaranalysis.Analyze tool. I am able to use the Weather.byLocation node to get the weather data but I would prefer to use my own .wea file. The reasons for this is that the base weather files included in revit have a location based cloud cover fraction included and I would like to run the analysis to get solar radiation values in a situation with no cloud cover.
I obtained the .wea file from Climate.onebuilding. org (https://climate.onebuilding.org/default.html)
I am using dynamo core 2.10.1.3976 with dynamo revit 2.10.1.4002.
Ultimately, I would like to be able to run solar analysis using my own .wea files. Any support would be appreciated!
