Hi everyone,
I want to adjust wall thicknesses using an Excel.However, he does find the walls with me but he indicates that it is impossible to adjust the walls.
Do you have a solution for this?Hi everyone,
Do you have a solution for this?Your family type input is a string, you have to put in the family type element.
Problably you just have to get rid of the str from object node.
Thanks for the comment, I just don’t think this is the solution he gives false but when I look in the custom node this comes away at the Layerindex
Do you really have 14 layers in all of those walls? Seems high… try using a layer index of 0 and see if that works. Note that you will be thickening the outermost finish layer on your walls.
