Wall Tag Orientation Problem
Hi everyone,
I am trying place tag with Dynamo. I do not have a problem for Horizantal or Vertical Wall elements. But I have a problem not horizantal or vertical walls. How to rotate or align tag to this elements.
Do you have any idea ? I am sharing screenshot.
As far I know is tag rotation only possible with the parameter Orientation.
When you try to rotate this element with Revit it’s not possible too.
Hi @jw.vanasselt , I think I saw Angle parameters in Tag element. Maybe we should use this parameter value , right ?
Ex. We can angle value X Vector and Wall Direcetion Vector ? How is this idea ?
Hi Guys,
You can try this to find the angle of the walls
Where did you see that parameter?
@jw.vanasselt As you change the angle, the tag angle also changes.
Learned something again thanks :slight_smile:
Which revit version do you use?
I use the architect sample template and don’t see this parameter.
@jw.vanasselt , I am using Revit 2022. I clicked the tag element. And I am seeing Angle Parameter and its value.
@volkan.isik , I understand your share. Which package did you use at above script ? ex WallCompoundStructureLayersLocation ?
Thank you so much.
@DynaGirlBIM You can also use Element.GetLocation
@jw.vanasselt I am using Revit 2022,
WallCompoundStructureLayersLocation and Create Tag nodes are from the Genius Loci package.
Thank you so much everyone -. Problem solved now :wink: @Alban_de_Chasteigner @volkan.isik @jw.vanasselt
Hi volkan.isik
Sounds great. But sorry for my ignorance, but can’f find Deconstruct.Curve is it part of a package?
