Hi, i’m trying to tag all my curtain wall panels in dynamo directly. (i know that you can do it using tag all in Revit). But since I’m new to Dynamo, I wanted to give it a shot. Could you tell me what I’m doing wrong?
Thanks in advance.
Thanks in advance.
Ok, I figured few things out while going through the other posts.
I did all this but now the tags are not placed correctly on the model elements as you can see the image. Any solution to this?
And also my nodes are being placed vertically. And when I remove the Vertical Alignment Style and run it, none of the tags are placed.
